Power pins reversed
08/31/2015 at 00:15 • 0 commentsI noticed last week while auditing designs that I messed up the power pin order. So it is now fixed in R0.5. Stencil will be the same, but I'll need to order new boards obviously.
Example keypad designs
08/17/2015 at 20:22 • 0 commentsWe will try to show how to build a keypad using flex. It should be pretty interesting if we can do it.
Need to make drivers
08/17/2015 at 20:21 • 0 commentsThis board is commonly used for keypad design, but it seems that few drivers are decent. We will likely need to make our own.
Stencil Ordered
08/17/2015 at 20:20 • 0 commentsWe have our stencil from oshstencils for this board.
Waiting on samples
08/17/2015 at 17:49 • 0 commentsWe need to order samples for this board before we can make and test it.
Chris Hamilton
