Silicone sleeve
08/17/2015 at 17:11 • 0 commentsWe are working on coating the sleeve in silicone. The circuit board may be coated directly.
Capacitive buttons
08/17/2015 at 17:10 • 0 commentsWe have added capacitive buttons in the hopes to bring more interactivity to the concept. It is similar to the notifier bracelet, though more public.
Initial design
08/16/2015 at 09:32 • 0 commentsThe sleeve is a bit large in this implementation. It should function well using a CR2450 or LIR2450. Later designs will utilize a curved LI Poly that will better fit narrow bands.
Waiting on functional charger
08/13/2015 at 11:09 • 0 commentsWe have had some weird issues with the Qi/USB charger. I believe I over complicated the management and will be swapping to a simpler fuel gauge and fixed Qi defaults.
Until then we can make a watch battery based version. The curved batteries have similar capacity as the LIR2450 which fit in the holders we have.
Heart rate monitor
08/13/2015 at 11:07 • 0 commentsIt is similar to work we have done on our massager concept. We will be implementing a heart rate monitor inside the watch band. Our ECG work with Plessey based electrodes has progressed, but it is complicated. We do have the new Pulse Flex Module and we will try that as well.
