Project boosterado power supplies inside new casing
08/04/2015 at 19:43 • 0 comments350 watt AC-DC from hobbyking to boost from, double channel DC-DC boost power supply to the left taking place in the case
Project boosterado casing update
08/04/2015 at 19:40 • 0 commentssoviet military equipment has been dumped from this alloy case to enhold boosterado lightsquare!
Time to put everything togeter piece by bit
07/29/2015 at 01:13 • 0 commentsA decent amount of craft and prototyping,
hacking went to fabricating square matrix of LEDs
firmly attached to massive passive planar square heatsink.
Two hacked boost power supplies are tuned,
CC power supply frame-heatsink construction under way.
all savings will soon be gone to thick copper.
