Quick demo board made with Eagle and working with GCC G++ OpenCM3 Makefile FreeRTOS CAN
Revision 10x10 v2 fixed. It works.
Updated FreeRTOS configuration.
I fixed some basic errors on the board:
I added a new layout 10cm x 8cm and sent it to a cheap Chinese PCB lab. I will upload some photos when receive it.
Added CH340G to UART1 for firmware burning through STM32F bootloader.
View all 5 project logs
Install ARM-GCC, makefile and stm32flash
sudo apt-get install gcc-arm-none-eabi makefile stm32flash git
Clone repo:
git clone https://github.com/yangosoft/stm32f103c8-board.git
Compile
cd stm32f103c8-board/code/freertos_stm32f103 make
View all 4 instructions
I have also make this but facing issue kindle check it out
https://gta-6.pro/gta-6-trailer/
BTW I got the hardware side done here. :) https://hackaday.io/project/6607-stm32f103-canadian-maid-breakout-board
¡That is a better board! And it's better routed.
arief ibrahim adha
Stefan Wagner
Ethan Durrant
arturo182
Yes, delete it Cancel
You are about to report the project "STM32f103c8 board", please tell us the reason.
