Find the Fail;-(
A project log for Mini-PCIe - PIC18LF2550 - DevBoard
Use your PIC-Projects on Mini-PCIe (USB/SMBus)
sandfrogSandfrog 12/21/2016 at 11:407 Comments
Wait long Time for the new PCB, Error from me and OSHPark, OSHPark forgets the VIAs and I order in the wrong thickness, i Order new and wait for the New One.
Lock very nice its better as the First Version and not usable.
Can you see whats is not ok ?
profecie wrote 03/30/2017 at 17:59 point
Could let me know the right thickness  on OSH Park?
oshpark wrote 12/21/2016 at 23:10 point
@Knudt sorry to see this happened.  please email support@oshpark.com and we'll see what we can do.
thanks,
drew fustini
<drew@oshpark.com>
Sandfrog wrote 12/21/2016 at 23:47 point
@oshpark
Is already okay, I've already opened a ticket for notice, and a new printed circuit board ordered.
Even if your mistake would not have been inside, I have also made a mistake and thus made the board unusable anyway.
davedarko wrote 12/21/2016 at 11:45 point
I guess you're talking about the edge connectors, can't you sand them down? @oshpark - is there a way to prevent something like that?
Sandfrog wrote 12/21/2016 at 11:47 point
No i have Edit the Text the Fail is the VIAs and my Fail the wrong thickness, Double error ;(
Sandfrog wrote 12/21/2016 at 12:00 point
The corners connectors are outside the specifications given by OSH Park, which is problematic with such circuit boards, but is not the problem there is enough sanding.
davedarko wrote 12/21/2016 at 12:00 point
ah okay. sry, was wild guessing :)
