strong mounts and pcb mounts
A project log for Multichannel Audio DSP Field Mixer Recorder
bluetooth app controlled professional portable DSP mixer.balanced audio IO,phantom power,flexible routing,ISO recording. timcode. AVB audio.
ben-bilesben biles 03/10/2021 at 11:210 Comments
I beefed up the upper lower case mounts where there was available space.
Also added some pcb mounts that don't require spacers.
