FIXED :) I2C and RST pin voltage too low
A project log for Multichannel Audio DSP Field Mixer Recorder
bluetooth app controlled professional portable DSP mixer.balanced audio IO,phantom power,flexible routing,ISO recording. timcode. AVB audio.
ben-bilesben biles 08/31/2015 at 13:410 Comments
OK !!! hooray !!! Fixed the I2C communication for the CS4385 DAC using my trusty state of the art volt meter :)
I had used a pullup resistor to try to make to reset pin high that was too large.
not enough voltage to pass threshold on Reset pin to power up DAC !!!
I also added 2 x 4.7k pullups ro the I2C bus. the voltages where around the 3v mark which seamed a fraction too low.. now there nearer 4v when high.
I have no idea if thats the correct thing to do !
can't remember where i got my volt meter from, maybe a christmas cracker ?
I really need an Osciloscope, was looking at the Agilent 2000 series, but a lot of money for me really and not even sure I really would need something that powerful.. although the cheaper Rigol stuff looks like a strange toy !!!
. can anyone surgest what a good one would be for looking at multiple SPI I2C port communications etc ?
anyway, I have 8 channels of DAC volume control and theres no noise at all !! must have got the sepperate digital / analouge grounds right this time. Amazing :) :)
Think its time to order that 8 channel ADC and hook it up to the 8 channel TDM !!!
I'll tidy up the code and make a video of this DAC mixing a couple of I2S audio sources as soon as I get time..
