basic testing of the power supply
A project log for Multichannel Audio DSP Field Mixer Recorder
bluetooth app controlled professional portable DSP mixer.balanced audio IO,phantom power,flexible routing,ISO recording. timcode. AVB audio.
ben-bilesben biles 02/10/2016 at 19:230 Comments
I'm doing more tests on the power supply since the first prototype board blew up number 1 pga2500. I think for some reason the power supply went higher that -5.5v on the negative supply. now the supply is just running three channels and i've been monitoring the voltages.
I get my Rigol DS2076A osciloscope tommorow, so looking forward to being able to check the power on too. Mainly checking all this before I start up the PCB version !! dont want to blow a pga2500 on one of the PCB's
I also need to wire up and test the Phantom48 switching IC before I add that to the PCB version.
