+-5v dual rail power 1amp per rail ! 20uV noise, phantom power & digi power 20uV noise
A project log for Multichannel Audio DSP Field Mixer Recorder
bluetooth app controlled professional portable DSP mixer.balanced audio IO,phantom power,flexible routing,ISO recording. timcode. AVB audio.
ben-bilesben biles 02/12/2017 at 16:310 Comments
+/-5v dual rail power 1amp per rail ! 20uV noise per rail.
phantom power 48v 50ma ( no filter yet working on it )
<edit> I tried all kinds of filters with inductors large capacitors etc , basically the ripple is a bit to agressive to be smoothed with a simple filter I think. its nearly 1vpp !! I think I will just add a 48v capable ultra low noise LDO on the next revision. looking like it will be LT3012 with 100 microVolts noise. :)
It looks like the large decoupling caps in the middle of the board can be replaced with ceramic 47uf 25v or so.
<edit>
& +5v 500ma digi power 20uV noise
phantom power has 120mV ripple and filter needs work but room for a large thru hole capacitor if needed.
tested 800ma per +- rail and it does'nt get hot at all.
it will run on 5.5 - 25v input
it can be configured for +-18v +-15v +-12v etc but need +/-5v for PGA2500's
rev 2 will have smaller inductor pads and I think I can swap electro caps for ceramic in middle of board. I need about 35uf in total there.
Not sure about large input caps yet , might need them to protect LDO's from inrush voltage / current so ceramic would'nt work there.
I'm thinking of adding a variable oscilator and syncing the chips, not sure if its worth the trouble.
