mixer map in DSP :)
A project log for Multichannel Audio DSP Field Mixer Recorder
bluetooth app controlled professional portable DSP mixer.balanced audio IO,phantom power,flexible routing,ISO recording. timcode. AVB audio.
ben-bilesben biles 09/04/2017 at 09:170 Comments
Its a bit simpler than this now , but its looks something like this !
I had to use mutes for the mix matrix , but now I'm using single volume splitters like on the right hand side to attenuate based on channel count.
