more work on the chassis / box
A project log for Multichannel Audio DSP Field Mixer Recorder
bluetooth app controlled professional portable DSP mixer.balanced audio IO,phantom power,flexible routing,ISO recording. timcode. AVB audio.
ben-bilesben biles 09/26/2021 at 12:180 Comments
I've started work on the case again and will print another in CF and will glue on some thin aluminium panels in recesses in the CF.
I am making plates for connectors that bolt to the chassis. so far only 2 plates , 1 for the mini XLR inputs / outputs and 1 panel for the AES IO mini XLR and 1/4" headphone sockets.
I made some slots in the digital and analogue main board mounts so I can slide in some EMI shielding between the 2 boards.
this is a very rough 3d thing of the assembly. you can click to make a cutaway.
https://grabcad.com/library/bbbox-1
