So the DAC is working and it sounds great ! I have a 8 Volume controls !!
But there is always a BUT in electronics design !!
mixing down to 2 channels ?
EDIT [ OK, just noticed there are 4 registers for these tables ] maybe I can make this work somehow . I think there are 4 stereo pairs. so if I add another DAC could I have 8 stereo pairs ? then I could have balance faders for each channel ? scratching my caveman brain here ]
I speed read a lot of data sheets trying to find an 8 channel DAC to use as a digital mixer.
I found the CS4385 had 8 channels of IO I2S input and 8 channels differntial output .. tick.
then noticed an ATAPI routing matrix chart thing and thought,, oh nice , I can mix the tracks to any given output.. HAHA !!! I think I am experiencing the beginer trap here !! see pictures below..
It appears like you can mix A channels and B channels to ??? so confusing..
essentially I'm probebly looking at changing the DAC for some kind of DSP that can route / mix incoming I2S channels to and from anywhere to anywhere.. but which one !! and they are so complicated.
also , are they power efficiant ? I am trying to make a low power simple flexible USBmidi mixer here !!! should I be using FPGA !! ?
