New Main board being drawn up ! ADC DSP ARM DAC !
A project log for Multichannel Audio DSP Field Mixer Recorder
bluetooth app controlled professional portable DSP mixer.balanced audio IO,phantom power,flexible routing,ISO recording. timcode. AVB audio.
ben-bilesben biles 01/20/2018 at 22:480 Comments
I will be using stm32f7xx to multichannel record/playback TDM8 to DSP
I should be putting the ADC and DAC onto a daughter card so I can change the IC's later but NO , I've already started
routing it now :) so far its about 10cm x 6cm and might be able to get smaller since i finally started using 0603 parts.
I'm not sure it can get any smaller because of heat ! There is fair amount going on here :)
Its a 4 layer board with partitioned ground analogue and digital ground plane.
i'll be using a 40 pin IDE cable to hook up the analouge IO and 5v power to the Preamp and driver board.
why ? because they are everywhere for free :)
I'm not really convinced I should be running the 3.3v LDO for the digital stuff ( DSP and ARM ) off the analogue +5v rail !
perhaps that could add noise to the analouge +5v rail on the preAmps ? anyone have any thoughts on that ?
Will the LDO put noise onto its input ? can I isolate this without transformers? or should I really have a whole other
channel to make the digital power?
