December 5, 2015: I got the rev 1 boards back and they worked, but the maximum current was only about 100 mA. Although I had used the same layout as I had used in a previous project, it really didn't do well at high current. The output voltage would drop. I have corrected the issue by following the layout guidelines in the datasheet to a T. The new files are posted on the project page.
I plan to order some rev 2 boards and try again.
CaptMcAllister
