600MHz NCO tested :)
08/02/2015 at 18:18 • 0 commentsWhile testing #Arduino Compatible Zynq Shield added simple non-enhanced DSP48E1 based NCO, one connected to output pin, one connected to on-board LED.
This NCO can run up to 600MHz clock in Xilinx 7 series FPGA's. It can be used as base building block to created enhanced versions of the NCO.
Bounty offer:
08/01/2015 at 11:01 • 0 commentsThis "enhanced NCO" is a project on my tasklist for many years already. One day I do it also. This is unfortunatly not an "impossible thing" it is a very possible project.
You think you can do it? This can be done and proved with simulation only..
Go ahead, do it, if you do it before I do, and post the code: I promise I take the time to test it, and if you ask, will send some Xilinx 7 series board free shipping. (I have too many FPGA boards!).
