Framing The Problem
A project log for Simple Small Robot
Robot designed as a starting point for 1 lb combat robots
andrew-schreiberAndrew Schreiber 08/07/2015 at 21:300 Comments
So, I decided to try out OnShape as a CAD software. Previously I'd worked primarily in CREO 2.0 and struggled with it (I know Solidworks and Inventor far better). I'm also a Mac user and using a VM to do CAD was annoying. So I heard about OnShape and decided to see if I could whip out a frame in it. Guess I can.
You can also copy the file and make modifications inside OnShape at (I assume) Mini Robot Frame
