With the use of the Arduino Example "KeyboardSerial" it's possible to send a serial command to the Arduino which converts the signal to a virtual Keystroke.
In this way my Compatibility Tool is able to send a serial byte to the Arduino and this will send the Keystroke to the game you're playing.
I hope it'll work after editing my Program in Delphi!
