Warpquad 230mm Drone Build
The very fast warpquad quadcopter drone.
The warpquad is a 230mm carbon fiber X frame that weighs in around 66 grams.
Total weight with battery 360 grams. The ~2800 grams of thrust from this setup is nearly 8:1 thrust to weight ratio.
SBUS input
DODO FC flashed with BorisB firmware
Looptime ~700
Updated Luxfloat PID controller
ESC flashed with BLHeli 14 and OneShot enabled
View all 7 components
  • Lost nut
    Richard Hogben09/02/2015 at 20:23 2 comments
    Brought this build out to a field for some flying. About four feet off the ground and ten seconds of airtime and a propeller and propeller nut flew off...
    Black propeller nut in green grass = lost. Lesson learned, make sure nuts are tight, and bring extra nuts.
View project log
honxen wrote 08/04/2015 at 17:31 point
Ah! I see , god luck with the maiden flight! :)
honxen wrote 08/04/2015 at 17:25 point
Nice drone!!
I like the frame :)
Richard Hogben wrote 08/04/2015 at 17:30 point
Thanks! I haven't had a chance to crash it yet, maybe this Friday :)
