mqtt for the win
A project log for I'm a fan of your fan
it's warm so I ordered some pc-case fans to stack them
davedarkodavedarko 08/06/2016 at 22:442 Comments
I recently played around with mqtt again and used one of my #Ignore this ESP8266 board -s to internet-of-thingify this fan construct. Searching for reasons why the uln2004 wouldn't work with 3.3V I tried pnps and npns until I found that I haven't declared the pins I was using as an output. I might have also connected the 12V with the 3.3V line while experimenting :D but in the end it turned out that I had also connected the fans backwards. Muah. But now it runs and I can control it via MQTT.fx - winning.
The ESP arduino soft PWM runs at 1kHz and I can hear it, that is kind of annoying.
Don't forget to set different clientIDs ;)
ANVA K wrote 08/08/2016 at 22:45 point
Hello can you  add VIDEO how make this ?
davedarko wrote 08/09/2016 at 08:53 point
Hey anva, do you mean the soldering part or the software part or both?
