Codes
A project log for DEFCON 23 Badge Hacking
Join in the fun and help hack the 2015 DEFCON Badge
murrielmurriel 08/07/2015 at 00:085 Comments
Update: more info here
http://pastebin.com/ZYFYtTt3
Not sure if there is s better way/place to post or dump info but here goes :
Transcribed from the program defcon times
Page 2
VgjbhyqagorQrspbajvgubhgbhetbbqsevraqPnrfne
(fbzrgenqvgvbafjvyyarireqvr)
Hjvyyxabjjung2qbjuraHhafpenzoyr “Ubjqnqqlvfqbvat”
WFST HDXE HGY BNK BAWH QJG PSOR WNFATG IDDW OQUHVNKINGCY GQG CTUK.
Also the binary from the handout today
01000100 01000101 01000110 00100000 01000011 01001111 01001110 00100000 01010000 01100001 01110010 01110100 01101001 01100101 01110011
Just converts to DEF CON Parties ;p
chaim.leib.halbert wrote 08/09/2015 at 08:47 point
On the number cipher, I tried all possible alphabet rotations, then mirrored the cipher wheel and tried all rotations again. It's not using a rotation cipher. I tried letter frequency analysis but this was difficult because the message is so short. A longer message would be too easy, wouldn't it?
Rob MacKinnon wrote 08/08/2015 at 19:08 point
The DTMF decode is T9, netting you the following two blocks delimited by "105710571057"
[1] = DJANDMTFAN
[2] = PEJDWPARGPDPDGPWDAPDTGDMTPGAMAJDQAMDWDAPDTGEPDAMDQMEPDAMP
Not sure if I'm working the decrypt correctly on the block 2 or not.  My attempt at a key...from working the ciphered text's common single/double/grouped letters nets definite words...but results in my words of "WTF does that mean?!".
JoyKil wrote 08/08/2015 at 19:42 point
What key gave you words? I can take a look at it...
commandhat38 wrote 08/07/2015 at 14:15 point
Don't know if it helps, but the Letter Number "cypher" decrypts to:
Z R J N U E Q M Q S V V T S V V H G H V L Y A N X L T B X L X J G G F N R B V Y R C F X G Y K I P N V L A X I Y B Q V I Z X E E T X G W Q R D M B K V W X K A G B K S F B M L Z I R M P X N L R E
Donglekiller wrote 08/07/2015 at 11:04 point
26 max number = Alphabet Letters
