HOW TO USE IT ?
Twiz modules are the most universal tools for wearable technologies, applications are simply endless but here are a few examples :
- Media control: modulate sound effects or control a light show from performers’ motion
- Scientific studies: analyse a building/bridge vibrations, animal activities…
- 2/3D Software: motion capture to animate 3D model of object, human or virtual creature
- Games: control your favorite doom-like from your hand, or breakout
- Anything that a beacon or activity tracker does
- Home automation: control your room's light volume by spinning your candle:
HARDWARE
MPU9150, 9 axis IMU motion sensor:
3D accelerometer for linear accelerations, 3D gyroscope for rotational accelerations, 3D magnetometer for orientation reference
nRF51822, processor + connectivity:
32 bit ARM processor with low consumption optimization (Cortex-M0), BLE (Bluetooth Low Energy AKA Bluetooth smart/4.0)
Physical characteristics :
2.4 cm x 2.4 cm (< 1 inch), 1.1cm thick (< ½ inch), 4.6g (~7.6g w/ battery)
It started with usual dev boards such as teensy, IMU and radio modules:
...but we shrunk it:
SOFTWARE
- Madwick fusion: send Euler angles or Quaternions
- ifttt recipes with our python/kivy interface
- experimentation using swift, noble
- open source: software / firmware / hardware (schematics, gerbers, BOM, etc.)
Software architecture:
Cedric Honnet
Juan Sandubete
Guillermo Herrera-Arcos
Hunter Santana
Can you send some command to your board and execute it by the CPU? e.g. changing state of some output pins? Like the LED on the video?
