I've had to take a pause again from working on this due to the day job, but quite a bit of progress has been made which I will detail in a later post. Just wanted to throw in an update of one part:
I want the USB ports to float in the controller ports like the original. So I designed and 3D printed some inserts. The printer I used was a Cube 2 printer (I don't recommend it - thankfully my work paid for it, not me!) They required quite a bit of trimming to fit properly even though I triple checked my measurements due to the inaccuracy of the printer. They are designed to snap into the slots on the sides of the controller port for a tight friction fit.
I am going to be redesigning these to have more of a floating look and hopefully a better fit. I plan to accomplish that by having only three points the length of the USB connector. I will post up the files for it once I get them just right for anyone wanting to do the same.
I am also planning to design and print a bezel for the lens on the front, but I am actually considering doing a chemical etch of some copper sheet for that instead.
Several other custom 3D printed parts are also in the works.
Stay tuned...
This is amazing. Do you still have the 3D print files? I am looking for something just like this.
