Silly me
A project log for N64 Retro Emulation Station conversion
This project is to build a standalone retro emulation station using the Cubieboard 2 (Arm A20) inside a modified N64 console
retroplayerRetroplayer 04/07/2014 at 22:360 Comments
Digging into the schematics for the Cubieboard tonight and focused on the power management IC. It is an AXP209, which has an integrated push on/off function which is controlled through linux. In fact, the power switch on the board is just a push button. So nothing special needed for this.
The AXP209 also has a lithium ion charger built in, as well as outputs to control point of load supplies to peripherals. These don't appear to be used, but hacking into these may be useful to shut down the supplies to the hard drive and USB hubs.
The datasheet is in Chinese and my Chinese is  a bit rusty (ok, it's non-existant.) But I am determined now to figure it out.
There is plenty of English information at the link below, however.
http://linux-sunxi.org/AXP209
