cube electronics
A project log for rgbcubes - iot finder
glowy cubes (ws2812b) made from frosted acrylic with web service to easily find it on your network.
christian-stvekenChristian Stöveken 04/12/2016 at 23:450 Comments
ws2812b on pcb for hassle free soldering.
4 pin connectors for +- 5V, signal and signal loop through if necessary for some setup.
Connectors should be protected against polarity reversal- otherwise I will always short sth.
helper (soldering) fairy
esp8266 breadboard test
