LPS Mini Adaptor
A project log for LPS Mini
Arduino compatible indoor navigation system with small form factor.
gran-nordahlGöran Nordahl 08/15/2015 at 21:530 Comments
We have made an adaptor for LPS Mini to give very easy access to all I/O, UART, ISP and power pins. The adaptor act as a bridge between TE Connectivity 5650712-1 (holds LPS Mini) and the standard Arduino Nano footprint. In most cases the adaptor is of no use except during test and debug. If all I/O is needed on a permanent basis, LPS might be a better choice than LPS Mini. The UART connector mates with FTDI USB TTL Serial Cable TTL-232R-3V3. The ISP connector mates with the standard AVR ISP 6-pin header.
