A new generation LPS boards
A project log for LPS Mini
Arduino compatible indoor navigation system with small form factor.
gran-nordahlGöran Nordahl 11/10/2016 at 22:530 Comments
We have spent several months working with Angle of Arrival (AoA). As a result we found reasons to redesign our latest generation of LPS boards a bit. This new board combines all our knowledge so far:
http://www.loligo.se/LPS2/LPS2.pdf
http://www.loligo.se/LPS2/LPS2.wmv
In short this is what LPS^2 can offer:
* ARM Cortex M4F.
* UWB.
* WiFi if needed (can be soldered in as a ESP12-E/F module).
* Can act as a RFID tag.
* Accelerometer/gyro/compass/altimeter/thermometer.
* TCXO or ordinary XTAL.
* Clock and sync handling/distribution for TDoA/AoA.
* Can charge a LiPo either from USB or a small solar panel.
* Can be controlled and reprogrammed via USB, BLE and WiFi.
* Extra flash for data storage.
* Size: 34x52 mm.
It will very soon be sent to production! :-)
As pointed out earlier this board will not replace any of our other boards, it is rather a complement with the ability to work as a TDoA/AoA anchor.
