Cranberry
A project log for LPS Mini
Arduino compatible indoor navigation system with small form factor.
gran-nordahlGöran Nordahl 12/23/2016 at 13:160 Comments
Yet another little board based on LPS^2 Mini (but without UWB) is ready for the factory! Cranberry has the same features as Blueberry (BLE/acc/gyro/compass/altimeter/RH/temp/light/UV), but can also handle up to four strain gauges / load cells! Size 26x26x9 mm, compared to 20x20x6 mm for Blueberry. Battery size CR2032 instead of CR1632.http://www.loligo.se/Cranberry/Cranberry.wmv
