Making Things Easier
A project log for ESP 8266 Web Server
A web server to display data from ESP8266/ESP32 WiFi devices
michael-otooleMichael O'Toole 11/18/2015 at 08:430 Comments
I'm looking into using Mongoose to run the server making things considerably easier for anyone not familiar with installing and running a fully fledged server... besides, Mongoose is tiny and does not require complex configuration...
I will need to switch from a database, to a file based record system, as no database support is included in mongoose by default...
I would ask anyone familiar with MQTT to post comments and suggestions as I have never used it and am somewhat lost as to how to implement it....
Updates:
I have tested Mosquitto (an MQTT broker/server ) using mqtt-spy and it works a treat. Mongoose (small server with php included and support for MQTT) and a replacement for the fully fledged WAMP server appears to works well too but I should note the version I downloaded costs $5...
The next stage is building a web page to take advantage MQTT...
Mike
