I ran into a small problem: the Arduino module is too big, and I can't fit the SD card reader inside!
So back to the drawing board!
I chose a smaller Arduino Mini board stacked on top of the SD reader. I had to chop some plastic off the support I printed to allow the slot to be exposed. The programming header is also broken out, to allow future debugging/reprogramming, without having to take the whole thing out of the rocket.
Hi, question about the radio transmitter. How are you using this to locate the rocket?
Hi!
I'm using the transmitter as a simple beacon: it transmits a continuous pulse, and with the help of a directional (yagi) antenna, I can direct myself towards the rocket. Here's an example of a use of that kind of tech:
http://www.instructables.com/id/433-MHz-UHF-lost-model-radio-beacon/
I plan to add in the future a GPS receiver and use it to send RTTY data through the 433MHz TX, to get a direct readout of the position...
awesome! really helpful link, also thanks for the quick reply$!
Build a bigger rocket :)
I'd like to keep it as light as possible, yet I want to stick the most powerful engine I can find (and afford!) in it! But I'm legally limited to 300m for now... :(
I follow the wanting to keep it small. I ended up finding a local club allowing higher launches via FAA permits, and to afford the bigger motors I built my own... Though probably didn't save money in the long run, almost 20 static tests and I have an effective motor design capable of hefting my rather large 6lb rocket skyward. I'm a fan of creating everything in a project, so everything including motor, rocket, nose cone, parachutes, and electronics are all custom in my project... Best of luck
