A3144
A project log for Shower Metronome
Minimize shower day dreaming, conserve a bit of water.
mulcmumulcmu 08/15/2015 at 04:351 Comment
Scavenged parts bin for hall effect sensor. Found a A3144. Hooked it up to the breadboard. Seems sensitive to magnet direction. Also discovered this breadboard LED widget has an open circuit. Pushing on the LED made it light up with the magnet held in place. At least this sensor doesn't latch and require magnet to flip to reset. It will work for the prototype.
mulcmu wrote 08/16/2015 at 00:26 point
Open circuit was due to pins on the LED breadboard bending to span the .45" gap between a row and column.  This must have bent the board or stressed solder joint between the resistor and LED.
