High Voltage Source
A project log for Inertial Electrostatic Confinement Fusor
A low-cost, experimental setup for D-D fusion
nathanstrachenNathanStrachen • 08/16/2015 at 22:54•0 Comments
The neutron counter that I purchased requires 1500 V to operate. I believe that the following source, coupled with a voltage divider, may be able to do the trick:
http://www.jameco.com/webapp/wcs/stores/servlet/Product_10001_10001_2100136_-1
