Vacuum Chamber
A project log for Inertial Electrostatic Confinement Fusor
A low-cost, experimental setup for D-D fusion
nathanstrachenNathanStrachen • 08/27/2015 at 04:00•0 Comments
An aluminum high vacuum chamber was just purchased for our project off of ebay. It was only about $100. It has an ID of about 6 inches. It should be very easy to machine and modify. If this chamber does not hold a sufficient vacuum, we plan on adding a glass bell jar over it to hopefully fix the problem.
