EL Bluetooth Controller
Simple demo showing Bluetooth controlled EL lighting for costumes.
Simple battery based EL controller that is ran by our Mini EL driver and 3db BLE Flex Module.
The design drives 4 channels of EL lighting by Bluetooth. Mini EL Flex Module and the 3dB BLE Flex Module are the main components running from a watch battery.
Any software related will be released under BSD or MIT license. SAAS or cloud based software will be AGPL.
Creative Commons License
  • 1 × 3dB BLE Flex Module
  • 1 × Mini EL Flex Module
  • 1 × 4P-RGB-Strip Flex Module
  • 1 × BC-2005 Battery Holder
  • Shape of flex
    Chris Hamilton08/17/2015 at 18:21 0 comments
    The flex on this board doesn't fold well to toward the EL connectors. We wanted to minimize the chance of shorting the high voltage with other traces. We might redo the design to further prevent this.
  • Battery source
    Chris Hamilton08/17/2015 at 18:19 0 comments
    In theory the watch batter should provide decent performance. We will be testing, but I expect that it will only last about an hour.
  • Charging
    Chris Hamilton08/16/2015 at 09:23 0 comments
    The design may be upgraded to a rechargeable design once we have a fully functional charger Flex Module.
  • Initial design
    Chris Hamilton08/16/2015 at 09:18 0 comments
    We put this together this week to show off the mini EL Flex Module. We used the connectors we have available, but we might change to another connector standard.
View all 4 project logs
