A project log for Valify V2 Robot Lawnmower
3D Printed Jetson TX2 based robotic lawnmower aims to build an "smart" robotic lawnmower using open technology
robin-frjdRobin Fröjd 04/10/2018 at 12:430 Comments
So this weekended I have been working on finishing the design of the drive system. I have updated the initial design of the 2-pulley gearing into a 4-pulley gearing. The main reason for the update is to have the ability the to achieve a lower wheel surface speed. The brackets are also designed with adjustable offsets, so each component can be adjusted to tighten the belt, or allowing a easy change off pulley sizes without redoing brackets.
Drive System Design Completion
My goal is a 0.4m/s wheel surface speed. Would give me 0.4*60/0.7225=33 RPM on the wheel shaft. So I am within the limits to achieve that. So this is the final design of the drive system.
Hopefully this week, CNC milling of motor brackets begins.
In the meantime I keep the printer busy with printing pulleys.
Sizes printed today is XL 10T, 50T and a 55T. Took a few test prints before I could find the sweet spot for the settings for a maximum belt grip.
3D printing drive belt pulleys
