A project log for Valify V2 Robot Lawnmower
3D Printed Jetson TX2 based robotic lawnmower aims to build an "smart" robotic lawnmower using open technology
robin-frjdRobin Fröjd 04/17/2018 at 12:440 Comments
Testing the 3D printed front nose. Looks quite good. Minor adjustments needs to be done.
Printed with PrimaSelect PETG @240C, 85C bed, 3shells and 15% infill (Very solid outcome).
-Countersink need to be adjusted to cut the body.
-The Integrated ZR300 camera need some cover on the back.
-Check if one can use a 90 degree USB instead of a normal USB head.
Raise3D n2+ Printing robot nose
3D printed robot nose valify
3D printed robot
3D printed nose test assembly
