FED2_012119.zipImproved pellet dispensingx-zip-compressed - 8.81 kB - 01/21/2019 at 22:25 |
FED2_SetClock.inoCode for setting the clock on the Feather RTCino - 5.09 kB - 05/26/2019 at 17:32 |
FED_analysis_script.zipPython analysis script and example FED datax-zip-compressed - 37.50 kB - 02/06/2019 at 17:50 |
FED2 libraries.zipLibraries to run FED - unzip to your Arduino/libraries directoryZip Archive - 3.84 MB - 08/21/2018 at 00:43 |
FED2_011419_20Hz_pulses.zipVariant that outputs 1s of 20Hz from the BNC connector when pellet is takenx-zip-compressed - 9.10 kB - 01/14/2019 at 21:03 |
FED2 operating instructions.pdfPDF with operating instructions - please comment and provide feedback!Adobe Portable Document Format - 2.05 MB - 03/12/2018 at 18:25 |
FED2.0 STL files.zipAll 6 STL files, updated 030418x-zip-compressed - 266.12 kB - 03/04/2018 at 18:58 |
TriggeredFED053018.zipNOTE: This is a variant of FED code that adds another input on Pin 5 to act as a "trigger" to dispense a pellet if there is not one already in the pellet well. Updated May 30, 2018Zip Archive - 315.69 kB - 06/05/2018 at 01:06 |
FED2_011419.zipMain code, with bug fix for BNC outputx-zip-compressed - 8.79 kB - 01/14/2019 at 21:03 |
FED2_012119_2minPulse.zipFED2 variant that delivers 2 minute pulse when pellet is takenx-zip-compressed - 9.49 kB - 01/21/2019 at 22:25 |
FED_V2_030818.zipOld stable version of the FED code - use if having trouble with more recent codex-zip-compressed - 10.22 kB - 03/11/2018 at 03:30 |
