Application Notes
- press-n-hold 1st row, 5th column (from top) for hp33C
- press-n-hold 2nd row, 5th column for hp25C
- press-n-hold 3nd row, 5th column for hp21
- press-n-hold 4th row, 4th column for version info
- press-n-hold 1st row, 4th column to show greetings
- press-n-hold 1st row, 3rd column to edit greetings, use 0-9 to enter numbers and letters, Run/Stop to advance digit, Cls to abandon entry
- press-n-hold Pgm/Run toggle button to edit default startup settings, use 'F' key to select rom, 'G' key to select speed, Pgm/Run will save setting and exit setup
Schematic
Chris Chung
matt oppenheim
Silícios Lab
sjm4306
Jess Eskow
In this thread you say that the 9 digit bubble LED module was defective. Could you explain please? I am currently playing with a Russian 9 digit module that is a clone of the HP, but it is not very bright when a current limiting resistor is used.
https://forum.43oh.com/topic/5524-tms08035-emulating-calculator-build/
Here is a video using 1K, it does not get much better going down to 560R
https://www.instagram.com/p/Bh2_0EcA4YS/
Thanks!
