Run your Hunter or Rainbird via Arduino.
We decoded the protocols of Hunter and Railbird irrigation controllers.
I have uploaded the SOURCE CODE as an .rtf
Public Chat
Please look in the files section of this project.
I have uploaded the Arduino Code to allow you to operate your Hunter and Rainbird controllers with an Arduino. Attach your arduino to a RPI and you're ready to run your old school irrigation controller from the cloud.
If it's hanging on the wall in your garage then The WATERKARMA dev board already owns it.
The thing that makes WATERKARMA special is that it offers full remote functionality of all the NAME BRAND irrigation controllers some of which are more than 15 years old. This is not a rain sensor circuit trick (I did that years ago).
Remotely Fire Zone 26 for 9 min or zone 3 for 2 min.
Most High End Commercial Grade Irrigation Controllers have more than 6, 8, or 12 zones.
This means that the user not only paid over $200 for their controller they more than likely paid an additional $200-$300 for expensive Zone Expansion Modules. How would you like to take a $500 piece of hardware off the wall in your garage and throw it in the TRASH??? It's NOT GONNA HAPPEN! How would you like to keep that controller and pay $100-$200 to convert it to a Cloud Based Algorithm Optimized Smart Controller that can be operated from a smart phone or computer??? Sounds like a no brainer to me. Since I've been a contractor working in the field for over 10 years I can say it would be infinitely easier to sell to a customer.
When WATERKARMA is combined with your project consumers won't have to drop more than $900 at the hardware store to purchase three 12 zone crap-io's and run 3 separate iPhone's with 3 separate Apple Id's if they have a system with 36 zones. No need to install, rewire and hang 3 separate controllers on their garage wall then have to buy an outlet splitter so they'll have somewhere to show off those 3 massive 24vAC Wall Warts.
If you have a two wire encoder/decoder irrigation controller than interfacing with that controller is a must.
THE WATERKARMA DEV BOARD IS FULLY COMPATIBLE WITH 2 WIRE ENCODER/DECODER SYSTEMS.
WATERKARMA CAN RUN AS MANY AS 200 ZONES ON A SINGLE EXISTING CONTROLLER.
Rich Text Format - 12.08 kB - 05/18/2021 at 00:27
Download
  • 1
    Step 1
    WK Arduino Software version 1-15-2015
    By: WATERKARMA
    Takes commands via serial port in this form: <S=_:Z=___:T=___:N=___>
    Sprinkler systems supported: Hunter, RainBird
    #include <LiquidCrystal.h>
    const int pinSerialOut = 12;
    const int pinSerialIn = 13;
    const int BuzzerPos = A5;
    const int BuzzerNeg = A2;
    int varZone = 1;
    int varTimeOn = 1;
    int varTemp_int;
    char varCharRecover_char;
    unsigned long varMillisSave_ulong;
    byte varTemp_byte = 0;
    char varCharSerialRead;
    char charMessageSys;
    int intMessageZone;
    int intMessageTime;
    int intMessageNote;
    String varString = "";
    // Hunter fx Variables
    String varP0_String = "11111111010000000000000";
    String varP1_String = "00000000000010000000000000";
    String varP2_String = "00000000000010000000000000";
    String varP3_String = "00000000000010000000000000";
    String varP4_String = "001101110000011111110";
    // RB fx Variables
    const int timetiltrans = 215; //manchester encoding stuff time in uS
    const int timeaftertrans = 150; //manchester encoding stuff time in uS
    byte arrayOn_Byte[] = {245,245,245,28,4,57,0,1,5,67,B00011100};  //on command zone info in arrayOn_Byte[7]=zone and arrayOn_Byte[9]=zone+66
    byte arrayOff_Byte[] = {245,245,245,28,1,64,65,B00011100};  //off command regardles of zone
    void setup()
      // Open Serial port
      Serial.begin(9600);
      Serial.println("<Initialized>");
      // Pin 13 has an LED connected on most Arduino boards:
      //  pinMode(0, INPUT);
      //  pinMode(1, INPUT);
      //  pinMode(2, INPUT);
      pinMode(8, OUTPUT);
      pinMode(9, OUTPUT);
      pinMode(4, OUTPUT);
      pinMode(5, OUTPUT);
      pinMode(6, OUTPUT);
      pinMode(7, OUTPUT);
      pinMode(11, INPUT);
      pinMode(12, OUTPUT);
      digitalWrite(12, HIGH);
      pinMode(13, INPUT);
      //digitalWrite(13, HIGH); // Pull up
      pinMode(BuzzerNeg, OUTPUT);
      digitalWrite(BuzzerNeg, LOW);
      pinMode(BuzzerPos, OUTPUT);
      digitalWrite(BuzzerPos, LOW);
      digitalWrite(BuzzerPos, 1);
      delay(100);
      digitalWrite(BuzzerPos, 0);
      delay(200);
      delay(100);
      delay(200);
      delay(100);
      delay(1000);
    void loop()  {
      while (Serial.available() > 0) Serial.read(); // Flush the serial receive buffer
      while (Serial.available() == 0)  delay(1);
      if (Serial.available() > 0)  {
        varMillisSave_ulong = millis();
        while ((Serial.available() < 23) && (millis() - varMillisSave_ulong < 250))  delay(1);
        if (Serial.available() < 23)  {
          Serial.println("<Timed Out - Message Short>");
        else  {
          varString = "";
          for (int i=0; i < 23; i++)  {
            varCharSerialRead = Serial.read();
            varString += varCharSerialRead;
          //Parse Message
          if (varString.indexOf('<') != 0)  Serial.println("Message Error - Begin Sentinel");
          else if (varString.indexOf('>') != 22)  Serial.println("Message Error - End Sentinel");
          else if (varString.charAt(1) != 'S')  Serial.println("Message Error - System Parameter");
          else if (varString.charAt(5) != 'Z')  Serial.println("Message Error - Zone Parameter");
          else if (varString.charAt(11) != 'T')  Serial.println("Message Error - Time Parameter");
          else if (varString.charAt(17) != 'N')  Serial.println("Message Error - Note Parameter");
          else  {
            //Passed all parameter checks
            charMessageSys = varString.charAt(3);
            intMessageZone = varString.substring(7,10).toInt();
            intMessageTime = varString.substring(13,16).toInt();
            intMessageNote = varString.substring(19,22).toInt();
            Serial.print("<Valid Message:S=");
            Serial.print(charMessageSys);
            Serial.print(":Z=");
            Serial.print(intMessageZone);
            Serial.print(":T=");
            Serial.print(intMessageTime);
            Serial.print(":N=");
            Serial.print(intMessageNote);
            Serial.println(">");
            if (charMessageSys == 'H')  {
              if (intMessageZone < 1)  varZone = 1;
              else if (intMessageZone > 48)  varZone = 48;
              else varZone = intMessageZone;
              if (intMessageTime < 0)  varTimeOn = 0;
              else if (intMessageTime > 90)  varTimeOn = 90;
              else varTimeOn = intMessageTime;
              fxPlayHunter();
            if (charMessageSys == 'R')  {
              else if (intMessageTime > 1)  varTimeOn = 1;
              fxPlayRB();
            Serial.print("<Message Sent:S=");
            Serial.print(varZone);
            Serial.print(varTimeOn);
      digitalWrite(A5, HIGH);
      delay(100);
      digitalWrite(A5, LOW);
    void fxPlayHunter()  {
      //Build message from the front starting with P0
      if (varZone < 13)  {  //Weird change in P0 but it only happens at the zone 12 to 13 transition, phew!
        varP0_String.setCharAt(9,'1');
        varP0_String.setCharAt(10,'0');
      else  {
        varP0_String.setCharAt(9,'0');
        varP0_String.setCharAt(10,'1');
      //P1 here
      varTemp_byte = varZone + 23;
      for (int i=0; i <= 6; i++)  {
        if (bitRead(varTemp_byte,i) == 0)  varP1_String.setCharAt(i,'0');
        else  varP1_String.setCharAt(i,'1');
        if (bitRead(varTemp_byte,i) == 0)  varP1_String.setCharAt(i + 13,'0');
        else  varP1_String.setCharAt(i + 13,'1');
      varTemp_byte = varTimeOn;
      for (int i=0; i <= 3; i++)  {
        if (bitRead(varTemp_byte,i) == 0)  varP1_String.setCharAt(i + 8,'0');
        else  varP1_String.setCharAt(i + 8,'1');
      for (int i=4; i <= 6; i++)  {
        if (bitRead(varTemp_byte,i) == 0)  varP1_String.setCharAt(i + 21 - 4,'0');
        else  varP1_String.setCharAt(i + 21 - 4,'1');
      //P2 here
      varTemp_byte = varZone + 35;
        if (bitRead(varTemp_byte,i) == 0)  varP2_String.setCharAt(i,'0');
        else  varP2_String.setCharAt(i,'1');
        if (bitRead(varTemp_byte,i) == 0)  varP2_String.setCharAt(i + 13,'0');
        else  varP2_String.setCharAt(i + 13,'1');
        if (bitRead(varTemp_byte,i) == 0)  varP2_String.setCharAt(i + 8,'0');
        else  varP2_String.setCharAt(i + 8,'1');
        if (bitRead(varTemp_byte,i) == 0)  varP2_String.setCharAt(i + 21 - 4,'0');
        else  varP2_String.setCharAt(i + 21 - 4,'1');
      //P3 here
      varTemp_byte = varZone + 47;
        if (bitRead(varTemp_byte,i) == 0)  varP3_String.setCharAt(i,'0');
        else  varP3_String.setCharAt(i,'1');
        if (bitRead(varTemp_byte,i) == 0)  varP3_String.setCharAt(i + 13,'0');
        else  varP3_String.setCharAt(i + 13,'1');
        if (bitRead(varTemp_byte,i) == 0)  varP3_String.setCharAt(i + 8,'0');
        else  varP3_String.setCharAt(i + 8,'1');
        if (bitRead(varTemp_byte,i) == 0)  varP3_String.setCharAt(i + 21 - 4,'0');
        else  varP3_String.setCharAt(i + 21 - 4,'1');
      //P4 here
      varTemp_byte = varZone - 1;
        if (bitRead(varTemp_byte,i) == 0)  varP4_String.setCharAt(i + 8,'0');
        else  varP4_String.setCharAt(i + 8,'1');
      varString = "";
      varString = varP0_String + varP1_String + varP2_String + varP3_String + varP4_String;
      delay(150);
      delay(100);
      digitalWrite(pinSerialOut, LOW);
      //Serial.print("L");
      delay(320);
      digitalWrite(pinSerialOut, HIGH);
      //Serial.print("H");
      delay(65);
      //Serial.println("L");
      delayMicroseconds(900);
      varTemp_int = varString.length() - 1;
      for (int i=0; i <= varTemp_int; i++)  {
        varCharRecover_char = varString.charAt(i);
        //Serial.write(varCharRecover_char);
        delayMicroseconds(225);
        if (varCharRecover_char == '0')  digitalWrite(pinSerialOut, HIGH);
        delayMicroseconds(1800);
      //Serial.println("");
      //Serial.println("End");
    void fxPlayRB()  {
      //Serial.print("Building ON message with zone: ");
      //Serial.println(varZone);
      arrayOn_Byte[7] = varZone;
      arrayOn_Byte[9] = varZone + 66;
      delay(150);
      delay(100);
      if (varTimeOn == 1)  {  // Send ON message
        for (int ii=0; ii <= 9; ii++)  {
          for (int i=7; i >= 0; i--)  {
            if (bitRead(arrayOn_Byte[ii],i) == 1)  {
              delayMicroseconds(timetiltrans);
              delayMicroseconds(timeaftertrans);
              //Serial.print("1");
            else  {
              //Serial.print("0");
          //Serial.print(" ");
        for (int i=7; i >= 1; i--)  {
          if (bitRead(arrayOn_Byte[10],i) == 1)  {
          else  {
      else  {  // Send OFF Message
        for (int ii=0; ii <= 6; ii++)  {
            if (bitRead(arrayOff_Byte[ii],i) == 1)  {
            else  {
          if (bitRead(arrayOff_Byte[7],i) == 1)  {
          else  {
      //Serial.println();
View all instructions
Andrew wrote 13 hours ago point
Thanks for posting the code! It's too late for me as I have replaced the hardware (it's awful), but I really hope others can make use of this to improve what they have if they are still using it.
chadclick wrote 14 hours ago point
int varZone = 1;
int varTimeOn = 1;
int varTemp_int;
int intMessageZone;
int intMessageTime;
int intMessageNote;
// RB fx Variables
void setup()
  // Open Serial port
  Serial.begin(9600);
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(11, INPUT);
  pinMode(13, INPUT);
  delay(100);
  delay(200);
  delay(100);
  delay(200);
  delay(100);
  delay(1000);
void loop()  {
    else  {
      varString = "";
      //Parse Message
      else  {
          fxPlayHunter();
          fxPlayRB();
  delay(100);
  else  {
  //P1 here
  //P2 here
  //P3 here
  //P4 here
  varString = "";
  delay(150);
  delay(100);
  delay(320);
  delay(65);
void fxPlayRB()  {
  delay(150);
  delay(100);
        else  {
      else  {
        else  {
      else  {
  //Serial.println();
Please cut and paste the source code below into the arduino app.
int varZone = 1;
int varTimeOn = 1;
int varTemp_int;
int intMessageZone;
int intMessageTime;
int intMessageNote;
// RB fx Variables
void setup()
  // Open Serial port
  Serial.begin(9600);
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(11, INPUT);
  pinMode(13, INPUT);
  delay(100);
  delay(200);
  delay(100);
  delay(200);
  delay(100);
  delay(1000);
void loop()  {
    else  {
      varString = "";
      //Parse Message
      else  {
          fxPlayHunter();
          fxPlayRB();
  delay(100);
  else  {
  //P1 here
  //P2 here
  //P3 here
  //P4 here
  varString = "";
  delay(150);
  delay(100);
  delay(320);
  delay(65);
void fxPlayRB()  {
  delay(150);
  delay(100);
        else  {
      else  {
        else  {
      else  {
  //Serial.println();
Andrew wrote 10/06/2017 at 22:21 point
Hi there.  Your board has been out of stock on Tindie for two years now.  Have you considered releasing your code, schematics, and PCB artwork under an Open license?  I have a Hunter X-Core I want to control remotely with an ESP8266.  I can rewrite some Arduino code I found elsewhere, but I would rather not have to.  Thanks.
John Matthias Syrinek wrote 04/22/2020 at 03:37 point
Same question - thank you!
Andrew wrote 04/22/2020 at 03:44 point
I wouldn't hold your breath. I got fed up with the awful user interface on the Hunter controller and replaced it with an ESP8266 running ESPeasy and controlled by Domoticz. So. Much. Better.
By: WATERKARMA
int varZone = 1;
int varTimeOn = 1;
int varTemp_int;
int intMessageZone;
int intMessageTime;
int intMessageNote;
// RB fx Variables
void setup()
  // Open Serial port
  Serial.begin(9600);
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(11, INPUT);
  pinMode(13, INPUT);
  delay(100);
  delay(200);
  delay(100);
  delay(200);
  delay(100);
  delay(1000);
void loop()  {
    else  {
      varString = "";
      //Parse Message
      else  {
          fxPlayHunter();
          fxPlayRB();
  delay(100);
  else  {
  //P1 here
  //P2 here
  //P3 here
  //P4 here
  varString = "";
  delay(150);
  delay(100);
  delay(320);
  delay(65);
void fxPlayRB()  {
  delay(150);
  delay(100);
        else  {
      else  {
        else  {
      else  {
  //Serial.println();
By: WATERKARMA
int varZone = 1;
int varTimeOn = 1;
int varTemp_int;
int intMessageZone;
int intMessageTime;
int intMessageNote;
// RB fx Variables
void setup()
  // Open Serial port
  Serial.begin(9600);
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(11, INPUT);
  pinMode(13, INPUT);
  delay(100);
  delay(200);
  delay(100);
  delay(200);
  delay(100);
  delay(1000);
void loop()  {
    else  {
      varString = "";
      //Parse Message
      else  {
          fxPlayHunter();
          fxPlayRB();
  delay(100);
  else  {
  //P1 here
  //P2 here
  //P3 here
  //P4 here
  varString = "";
  delay(150);
  delay(100);
  delay(320);
  delay(65);
void fxPlayRB()  {
  delay(150);
  delay(100);
        else  {
      else  {
        else  {
      else  {
  //Serial.println();
Uploaded source code today.
Jim wrote 11/01/2016 at 20:06 point
Hi, I have 2 12-Station SST1200o on my property.  Can we make the Waterkarma board work with these controllers?  If so, I will need details.
Ramanan wrote 08/11/2016 at 17:14 point
Hi, we have a Rainbird ESP-ME system. Can you send me the details of how to connect the Waterkarma board to it. After reviewing, I would like to purchase such a board.
By: WATERKARMA
int varZone = 1;
int varTimeOn = 1;
int varTemp_int;
int intMessageZone;
int intMessageTime;
int intMessageNote;
// RB fx Variables
void setup()
  // Open Serial port
  Serial.begin(9600);
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(11, INPUT);
  pinMode(13, INPUT);
  delay(100);
  delay(200);
  delay(100);
  delay(200);
  delay(100);
  delay(1000);
void loop()  {
    else  {
      varString = "";
      //Parse Message
      else  {
          fxPlayHunter();
          fxPlayRB();
  delay(100);
  else  {
  //P1 here
  //P2 here
  //P3 here
  //P4 here
  varString = "";
  delay(150);
  delay(100);
  delay(320);
  delay(65);
void fxPlayRB()  {
  delay(150);
  delay(100);
        else  {
      else  {
        else  {
      else  {
  //Serial.println();
chadclick wrote 09/07/2015 at 06:07 point
I sell on Tindie
chadclick wrote 08/27/2015 at 01:32 point
Oh, forgot to mention we did a full tear down on the Rachio and while it's name implies Input/Output, ".io" it's not.  It's one way comm only.  No sensor data, nada.  It's about 1/4 the quality of a Hunter Pro-C or Rain Bird Esp.  The Rachio pcb and hardware config is lacking.
chadclick wrote 08/27/2015 at 01:28 point
You have a 36 zone irrigation system at your estate.  Last year you purchased a Hunter ACC encoder/decoder system ($2000).   All your friends are controlling their systems via iPhone and since you vacation 6 months out the year you'd like to do that too.  Right now you have pretty much one option.  Buy 3 Rachio 12 zone units, get 3 phones and 3 apple Id's .  The Rachios will set you back  $900 alone.  Then take your $2000 Hunter ACC off the wall and throw it in the trash can.  Make sure to have your irrigation contractor do the entire install/rebuild ($1000+).  It doesn't make sense.  I have the Plug and Play Cloud Based conversion module that is the solution.
Hentry Sombers wrote 08/27/2015 at 00:59 point
Interesting concept.  So this would work like an rach.io or the others.?  I guess this keeps the electrical hardware in place and adds a smart control for limiting and controlling watering based on rain/weather etc
By: WATERKARMA
int varZone = 1;
int varTimeOn = 1;
int varTemp_int;
int intMessageZone;
int intMessageTime;
int intMessageNote;
// RB fx Variables
void setup()
  // Open Serial port
  Serial.begin(9600);
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(11, INPUT);
  pinMode(13, INPUT);
  delay(100);
  delay(200);
  delay(100);
  delay(200);
  delay(100);
  delay(1000);
void loop()  {
    else  {
      varString = "";
      //Parse Message
      else  {
          fxPlayHunter();
          fxPlayRB();
  delay(100);
  else  {
  //P1 here
  //P2 here
  //P3 here
  //P4 here
  varString = "";
  delay(150);
  delay(100);
  delay(320);
  delay(65);
void fxPlayRB()  {
  delay(150);
  delay(100);
        else  {
      else  {
        else  {
      else  {
  //Serial.println();
