Hackaday.io Hackaday.io
Sign up Log in
Beautiful Fonts on ILI9341 TFT Displays
paul-stoffregenPaul Stoffregen
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
22.1k views
5 comments
23 followers
  • Description
  • Details
  • Files 0
  • Components 4
    • View all
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 5
View Gallery
22.1k
5
23
19
Team (1)
  • paul-stoffregenPaul Stoffregen
Join this project's team
ongoing project
Related lists
esp
esp32 and esp8266 list
This project was created on 08/18/2015 and last updated 11 years ago.
Description
These little 320x240 pixel color displays are inexpensive and easy to use with microcontrollers. But normally, only an ugly 7x5 font is available. This project aims to make lots of proper fonts work, at sizes ranging from tiny to really large characters. The font files are on Github, here: https://github.com/PaulStoffregen/ILI9341_fonts The font drawing code is currently here: https://github.com/PaulStoffregen/ILI9341_t3
Components
  • 1 × 320x240 Color TFT Display ILI9341 controller, SPI interface, typical $5 to $9
  • 1 × Teensy 3.1
  • 1 × PCB https://oshpark.com/shared_projects/IWylNfzD
  • 1 × 100 ohm resistor
Project Logs
Collapse
  • Importing Liberation Font Set
    Paul Stoffregen • 08/18/2015 at 14:00 • 0 comments
  • Importing Commonly Used Fonts
    Paul Stoffregen • 08/18/2015 at 13:58 • 0 comments
    More Fonts!!
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
creative fonts wrote 02/23/2024 at 11:34 • point
CreativeFonts. CreativeFonts is one of the latest fonts websites in the world. The website is straightforward to use and it contains over 60.000 fonts. You can use the search feature, or you can look for a font you like by browsing through the different categories that are available. CreativeFonts
philipswilliam87 wrote 12/15/2022 at 19:12 • point
Wow, your project is such a great. As I have learned something new by reading this project. Would like to share it with the team members of https://www.dcfont.com/glitter-text/ so that they could also read it and can implement something new in our running projects.
balo128908 wrote 11/01/2022 at 12:04 • point
DaFont. DaFont is one of the oldest fonts websites in the world. The website is straightforward to use and it contains north of 60.000 fonts. You can use the search feature, or you can look for a font you like by browsing through the different categories that are available. dafonts review
nvgadhiya wrote 04/04/2022 at 04:21 • point
I want to display Hindi language text on ILI9341 TFT Displays.
How is it do ?
Mahira Alex wrote 01/25/2022 at 07:27 • point
There are a couple of fast versions for the adafruit library but the standard fonts are horrible above a certain size and the way adafruit implemented custom font rendering causes them to blink on refresh. I guess what I would be looking for was something like UTFT, but UTFT runs very slow regardless of the hardware (ARM, AVR, ESP, HW, SW, etc).
Is a monochrome graphic display the only way to get a display with a decent refresh the page: https://insta-fonts com
Calculating project
Project Owner Contributor
CalcLab
adamAdam
Had an extra Ws2811b strip, saw this lamp gathering dust, figured why not make WiFi Controlled Animated Lamp
WS2811 Paper Lamp W. 2866 Web Srv Based Controler
e-bellE Bell
Celebrating US Independence Day on Vacuum Fluorescent Displays! feat. 8051 and GU20X8 display
bit_banged_banner
ethan-durrantEthan Durrant
Simple project to replace the headband of a set of Razer Blackshark headphones with the more sturdy Comtac headband
Blackshark Comtac headband replacement
tobiasTobias
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Beautiful Fonts on ILI9341 TFT Displays", please tell us the reason.
Send message
Remove Member
