A ridiculously big MIDI keyboard (121 keys)
2 x dirt-cheap Keystation 61ES = a ridiculously big MIDI keyboard !
Three years ago, I decided to learn piano. But damn, those are expensive for a beginner. Someone gave me for free an old synth, a PSR-210, but I quickly become annoyed of its light feeling and crappy sound. Then I found a broken yellowish Keystation 61ES nearly for free : A CMOS output died on the µC that scans the keys, so I had to replace it with an Atmega8 and some shift registers. It worked well after. But 61 keys ... sometimes it's not enough, and it can be quite frustrating. However, I recently stumbled across another one, for the third of its price ! I immediately bought It, with the ridiculous idea of this 121 Keys MIDI Keyboard !
1+1=2, no ?
Well that's not that simple.
First, keyboards have an annoying feature : an extra C key after the last octave, so it have to be removed : the U-shaped steel bed have to be cut as well as the PCB, and cut traces have to be repaired.
Secondly, another bed have to be made to hold the two keyboard together, and rigid enough so the whole keyboard will not bend. U and L shaped aluminum bar are the way to go. Optionally some cosmetic aluminum flat bars to hide the top of the keyboard and the end of the keys.
That should be enough for the mechanical issues.
The electronic circuit should be quite simple : 4x74164 parallel-out serial shift registers to select the 8x4=32 banks of 8 switches (so 32x8 = 256 switches, and 2 switches = 1 key so 128 keys max. ), with an Amega8 to select the banks sequentially / interpret the switch states on a 8bit port, to finally generate the MIDI key events with their velocities on a serial port. More details later on scanning techniques.
Optionally, an analog multiplexer (4051) to measure the resistance of switches (around 70ohms) for some MIDI pressure control ? An STM32F4Discovery as a synth + serial midi<->usb interface ?
  • 2 × M-Audio keystation 61es Preferably electronically dead
  • 1 × 2m*2cm*2cm U-shaped aluminum bar only 1.65m is needed
  • 1 × 2m*2cm*1.5cm L-shaped aluminium bar only 1.65m is needed
  • 1 × Atmega88a Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers
  • 1 × Atmega88a - Misc Crystal, capacitors ...
View all 7 components
  • The Aluminum frame is finished !
    Kaeipnos • 08/25/2015 at 18:24 • 0 comments
    After three days of hard work, it's done.
    Sure it's a tad heavy, but I find it marvelous.
    Rounded corners ! Too bad I fixed the upper bar too high : the tips of the keys are partially visible :(
    Behind !
    A blurry picture of the frame.
    The hard part is over, and I don't want to mess with it again. Now it's time for some electronics and software !
  • Merge both keyboards
    Kaeipnos • 08/21/2015 at 16:31 • 0 comments
    First the redundant C6 key had to be sawed off.
    Ok. Let's build the main frame that will hold the two keyboards together. After much hesitation in the hardware store I picked two L and U shaped aluminum bars, 1.5mm thickness.
    It seems rigid enough. The U bar could be overkill.
    After drilling some holes and reusing the screws, here is the result ! The traces of the C6 key had not yet been removed on the PCB.
    The first keyboard I bough had yellow keys, probably because of the sun. It seems possible to revert them to white by polishing them (hard way) or diving them in Retr0bright (not sure it would work). Now I have an extra key to experiment on so I one day could try retrobright on it.
    Having one half yellow and the other white is a bit weird so I decided to alternate both colors from one octave to another.
    I have to say that unlike my lousy PSR-210, those keyboards are quite easy to modify : keys can be removed and replaced without difficulty, and without breaking something in the process.
    I'm quite happy with the result : there is no visible gap between keyboards and the structure is super rigid. Granted, it's not really portable, but surprisingly it's not that heavy (I should weigh it one day). Too bad the embedded frame is in steel :(
    Next step : make a basic support beneath the keyboard, as well as something to hide the top of the keys(springs) and their end.
  • Tear everything apart !
    Kaeipnos • 08/20/2015 at 19:08 • 0 comments
    That delicious moment when you cleared all this occluding plastic and you start to grasp how everything works/worked ... especially when you have removed a hundred of screws .Too bad I didn't took many relevant photos.
    Keyboard 2 - Vanilla
    Observe the spring mechanism, the 121 diodes and the green pcb of the µC that we will happily remove.
    A 8052 variant. Notice that the decoupling capacitors are faaar away from its Vcc pin : Lack of knowledge , space constraints or evil built-in obsolescence ? Even weirder, power is fed trough a 10ohms resistor to make a strange RC filter ... am I missing something of this is a broken design ?!
    Yellowish Keyboard 1 - Modded
    The previous DIY alternative that uses an Atmega8 and two shift registers to scan the keys. Every generated event is sent to a serial port, acquired by the pc through a serial<>usb converter and whatever serial<>midi software.
    The 2 switches per key. The last C key (right) will be removed.
    So absurdly long.
View all 3 project logs
jcan wrote 05/08/2019 at 23:51 • point
Great!!!,, I am interested in your project. I also have Yamaha P105 keyboard (88 key), main Midi Board and power board broken....
So, I am also tring to make midi board using by arduino. If you don't mind. Could you sharing your skill??? hardware software???
Tikhon Orlovich wrote 04/25/2019 at 05:50 • point
Hi kaeipnos,
I salute you and doff my hat in deference to you for your ability to carry through this ambitious project.
You da Man! Bravo, Bravissimo, Bravo.
What I meant by Sonic soundscape heaven is simply derived from a concept of Ultrasymphonic Sound that can figuratively fill the Universe with sound that dazzles the mind with colors and timbres.  If you are more curious, look up Olivier Latry improvisations at Notre-Dame de Paris. There is a video timed at 9mins57secs on Youtube where Olivier shows what can be done on a Ultrasymphonic instrument.  Again I salute you, sir! Congrats on a job excellently done.
Ken Yap wrote 04/25/2019 at 00:21 • point
I like the cat accompanist.
Tikhon Orlovich wrote 03/28/2019 at 16:57 • point
Of course, seeing this project with a 121 note keyboard, WOW, a keyboard that can help one render a 128' pitch - 4 hertz low note...My, oh my! Sonic soundscape heaven........
Kaeipnos wrote 04/24/2019 at 21:49 • point
Indeed, with 121 keys this barely fits the 128 keys midi standard, which is a bit of an overkill.  The two extreme, often out of reach, octaves are barely used, so I remapped some of their keys to change scale or some useful midi events.
Sonic soundscape heaven ?
Tikhon Orlovich wrote 03/28/2019 at 16:53 • point
Did this project ever get completed? It certainly fired up my imagination.  As an organist I always dreamt about a performance instrument with three 116 note keyboards and a 39 note pedal clavier.
Kaeipnos wrote 04/24/2019 at 21:26 • point
Actually yes !  It is now a fully working USB MIDI keyboard with decent press/release sensitivity. Not only it is done it is usable and I consider it -finished- (whoah). I guess the hardware/software was a bit tricky to find at the time and I did not spend much time to document it here on hackaday.
However I will have some time in a few days, I will try to document the electronics and the software, I guess the hw/sw might be useful for similar projects :)
