Contents:
Added:
Note: that green LED-looking thing isn't just an LED. That long assembly is from a scanner, presumably CMOS. I want someone to turn the lightbulb wire assembly into an ESP-based light. And if you can get that hexbug working, keep it! The large chip (bottom left) comes with little information, check out the electronics grab box teardown (from electronics goldmine) for all I know about it.
Removed: 1 ESP-01, 1 Nano knockoff, that fancy LED switch, one of those large LCD displays, and stickers.
alpha_ninja
Great log-entry title :)
