Increase Camcorder Power Supply Time, proprietary
Increase Camcorder Power Supply Time. How I hacked an odd shaped, (proprietary).
Increase Camcorder Power Supply Time. How I hacked an odd shaped, (proprietary). How I hacked an odd shaped, (proprietary), plug to my JVC GZ-HM960BEK Camcorder to my power supply to use a Battery Bank LCD External Power Backup Dual USB Battery Charger to increase the Camcorder battery time This has shown to be reliable over many, many months of use. I mainly use as a backup power for my Camcorder it gives me much longer Camcorder battery time I use this with a hack to the power lead for a JVC GZ-HM960BEK but this hack can be used for almost any USB charged unit. This has shown to be reliable over many, many months, years, of use. I mainly use as a backup power for my Camcorder it gives me much longer Camcorder battery time:- How to video, Increase Camcorder Power Supply Time <a href="http://dai.ly/x2dzpaq" target="_blank">http://dai.ly/x2dzpaq</a>
Method
Only do this if you are confident with electrics and that you can achieve it safely, only for 5 Volts USB supplies.
Check all wiring and voltages, etc..
Use a USB extension cable, (a short one will quite often do).
Cut the USB extension cable in half, then you have a USB socket with a cable and a USB plug with a cable.
If the Power supply unit normally goes directly to the camera cut this USB power cable at a suitable place, allow for wire movements', etc..
Use the USB socket from the cut USB extension cable to join to the Power Supply Unit. Use insulation for example heat shrink tubing connect correct wires.
Now you have the power supply with a USB socket fitted. This may be used as a power supply to plug in any suitable USB unit.
Join the cut USB extension cable plug to the power cable odd shaped, (proprietary), that is the camera, (in this case, but could be for anything). Use insulation for example heat shrink tubing connect correct wires.
This USB Plug, that is now connected to the cable that went in to the camera odd shaped, (proprietary), may be plugged this hacked USB socket that is now on the power supply unit. I use this for longer Camcorder time by plugging into a USB battery pack.
USB battery pack.:-
Unboxing, review of LCD External Power Backup Dual USB Battery Charger
http://www.dailymotion.com/video/x2gy17i_unboxing-review-of-lcd-external-power-backup-dual-usb-battery-charger_tech
  • 1 × Original power supply Unit. Thie USB Power cable will need to be cut and joined to other parts
  • 1 × USB extension cable. Thie xtension cable will need to be cut and joined to other parts
  • 1 × Solder, wire cutters, heat shrink tubing, etc.. For joining wires together, etc..
  • 1 × USB battery pack. For longer power supply, gives hours run time
View all instructions
