Out of Resourses
A project log for AVR Arduino Development Board
A custom AVR Development Board to build modular projects
julian-labuschagneJulian Labuschagne 08/30/2015 at 11:530 Comments
"You require more vespene gas!"
This Saturday I sat down at my bench sorted all my components together, started warming up my soldering station. Reached for my tube velleman 17gr of 60/40 rosin core solder and noticed it was empty!
Living in South Africa on a tight budget I usually have to buy in small quantities.
I also only have one protoboard left to use for this project and from my last experience screwing up is easy to do especially if you are a noob like me. I mean just a few days ago I blew my fuse on my multimeter by trying to measure amps directly from my breadboard power supply.
I have made a plan and ordered 200gr solder and 5 more protoboards, by next weekend I should be restocked and organised.
I will spend the day drawing a schematic of the project and upload here.
Does anybody else sometimes run into a day where you just don't have any stuff to work with?
