DC/DC power
A project log for 12V Lasercutter
This laser cutter is made of a wooden base and some metal rails. It's very cheap and uses RaspberryPi for all, data and control.
jack-pearseJack Pearse 09/30/2015 at 11:160 Comments
As I promised the cutter will be connectable to a home solar kit. That means that you want to connect it to a 12V or 24V DC power source. Unfortunately lead batteries vary their voltage depending on their stored energy. A full battery has a voltage of approx. 13V, an empty battery has a voltage of about 10V.
I use two DC/DC converters to get the voltage down to 5V for operating the raspberry PI.
You can use any DC/DC breakout board. An Example is this one: https://www.sparkfun.com/products/9370
I purchased these: http://www.ebay.com/itm/5Pcs-Output-1-23V-30V-DC-DC-Buck-Converter-Step-Down-Module-LM2596-Power-Supply-/321476590827?hash=item4ad97f7ceb which are based on the LM2596.
