LaserWeb is out there
A project log for 12V Lasercutter
This laser cutter is made of a wooden base and some metal rails. It's very cheap and uses RaspberryPi for all, data and control.
Jack PearseJack Pearse 01/27/2016 at 13:120 Comments
Paul today showed me this:
http://hackaday.com/2016/01/26/stop-driving-laser-cutters-with-3d-printer-software/
So I will implement that to the raspberryPI 2 as a PC and then use an arduino using GRBL to control the laser cutter.
I still think that G-Code is deprecated.
