Hackaday.io Hackaday.io
Sign up Log in
Arduino RTD Shield
Arduino shield that can connect to multiple RTD temperature sensors at the same time
protovoltaicsProtoVoltaics
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
4.9k views
8 comments
1.2k followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 8
View Gallery
4.9k
8
1.2k
6
Team (1)
  • protovoltaicsProtoVoltaics
Join this project's team
  • Protovoltaics
  • Code
completed project
arduino temp temperature sensor precision protovoltaics
This project was created on 08/25/2015 and last updated 9 years ago.
Description
The shield has connections for either four 3-wire RTD temperature sensors or three 4-channel RTD temperature sensors or seven 2-wire RTD temperature sensors. An Arduino software library is available below that will make it super easy for you to get temperature readings. Works with 4-wire, 3-wire, and 2-wire RTDs. Works with Pt-100 and Pt-1000 RTDs. It can also be used as a precision ohmmeter for the Arduino to measure up to 8600 ohms. This shield uses the ADS1248 analog-to-digital converter (ADC) from Texas Instruments. It features 24-bit resolution (the Arduino ADC is only 10-bit), a programmable gain amplifier (up to 128x), multiple programmable precision current sources, and a ratiometric RTD drive topology to provide you with laboratory-grade, precision readings even in electrically noisy environments. All of these settings have been pre-configured!
Project Logs
Collapse
  • Watch it be built!
    ProtoVoltaics • 08/26/2015 at 14:07 • 0 comments
    Hello, we have recently been working on a machine to populate these board for us. Our very own homemade Pick and Place machine has successfully placed its first batch of 12 units.
    Check out the project at https://hackaday.io/project/5200-pick-and-place-machine
View project log
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
ftsoft wrote 07/07/2017 at 11:29 • point
Hello, is it still possible to buy your RTD shield now?
Andrew wrote 03/30/2017 at 16:07 • point
Hello, is it still possible to buy your RTD shield?
MicroPrototype & Design wrote 08/26/2015 at 14:18 • point
Will you be open sourcing the hardware ?
ProtoVoltaics wrote 08/26/2015 at 15:10 • point
We do not currently have plans to open source this project. These boards are now available for purchase.
zaidsayes wrote 04/22/2020 at 05:23 • point
hello there, can you please help me purchasing this board, i searched everywhere on Google and couldn't find where i can buy it from. need help please, we have a  project to build with RTD and arduino
MicroPrototype & Design wrote 08/26/2015 at 13:17 • point
What is the purpose of the PIC24 ?
ProtoVoltaics wrote 08/26/2015 at 14:05 • point
Hello, the PIC24 does the communication translation.
ProtoVoltaics wrote 08/26/2015 at 14:12 • point
It also does a minor amount of averaging.
The 2017 Hackaday Prize
PCR machines copy DNA. The CCPCR uses a coffee cup, an Arduino and a few other items.Cost to build is about 25$.
Project Owner Contributor
Coffee Cup Polymerase Chain Reaction Machine
paul-mccabePaul McCabe
A two digit Nixie thermometer.
Nixie Thermometer Shield for Arduino
my-electronicsMy Electronics
Measure high temperatures with type K thermocouples (1300ÂșC).
Arduino Type K temperature indicator
joseanbraserojosean.brasero
You will learn how to program ATTINY and create a thermometer with ATTINY85.
How to create a termometter with ATTINY85 and LM35
moreiraMoreira
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Arduino RTD Shield", please tell us the reason.
Send message
Remove Member
