Tentacle Emerges
A project log for Ivan the Teambuilt Robot
An e-NABLE robotics project to give hands to those without use of their hands. Designed with your help.
les-hallLes Hall 09/06/2015 at 08:001 Comment
Above we see a roughly sketched out tentacle arm with three solenoids per segment and five segments. The value of l is the length of each solenoid, which varies linearly. The height of each solenoid is given by z, which is an integration of l plus added thickness for the base. The printer is capable of printing flex, magnetic iron, and carbon Fiber PLA among other materials, so we can make all the single-material parts we need for this design.
Eric Hertz wrote 09/06/2015 at 11:20 point
Ivan's growing so quickly!
