Micro Bedside Clock
Using the HP bubble displays, a small, unobtrusive bedside clock, with day, date, seconds and (eventually) ambient light detection.
Using the DoubleBubbleBackpack from TinkerTroniks.com (purchased on Tindie)
Features include:
-dimming at 10pm and brightening at 7am (no auto-brightness control as yet)
-display of time in 24hr format
-display of day switching every 10 seconds with display of date
-counting seconds on the decimal points (from 4 to 64)
-animation on minute change
-felt feet
-magneticly secured enclosure allowing for easy maintenance (and no hinges)
Demo:
early test of features:
Its still a bit bright at night, so will look into dimming the display beyond brightness level 0
  • Build
    David Hopkins09/03/2015 at 09:34 0 comments
    Bits arrived, the project happened :-)
    Boxes were bought from the Range, I think they are meant for découpage or something but work well as little wooden project boxes it seems.
    remove hinges:
    Also, add extra magnets in addition to the 'clasp' magnet.
    Cut hole for Arduino Nano to poke through (Power and programming):
    A bit messy but the wood is softer than I thought, will be filled with something (probably hot-melt glue) and will be unseen.
    Filled with glue making it flush:
    Measure twice, and cut hole for bubble display:
    Mount and solder the bits. including plug for front which allows the thing to separate into 2 parts, making it easier to work on just one bit.
    The 6th wire (clear) is in place for future use with a light sensor, but it dims itself at 10pm and brightens at 7am so its not a problem at the moment.
    Running:
    I wish the camera would focus on LED's properly, but hey ho.
View project log
David Hopkins wrote 08/27/2015 at 14:29 point
Ah yes, I remember seeing that in HaD, a very nice build, and I also, have had bad experiences with the DS1307 (when building https://hackaday.io/project/3045), cheaper but pretty useless as it does not have temperature compensation.
