- Did I mention I want this to be bright? Like hand-held headlight sort of bright? Initially I thought this type of thing would be a cakewalk. I mean, everyone's first project is just figuring out how to light up an LED, right? Well I tried that, but even a string of high brightness white LEDs is just enough light to read by. I've settled on a pair of Cree XML2 wide angle high powered LEDs, which can be driven by up to 3 amps constant current. That's more like it.
- Dimmable because why not. The challenge here was finding a constant current driver with a PWM input and a small enough form factor to cram into an 80mm ball with everything else. I settled on a 1 amp driver because I also have concerns about controlling heat dissipation. This forced me either to use a 2S Lipo to drive the LEDs in series with one driver or to use two drivers and consume 2 amps at full power from a 1S Lipo. I decided on the series configuration as that should also help with battery life.
- Wireless charging. A 5V wireless charging module was easy enough to find. Of course, this would only be capable of charging a 1S lipo. That means I need a way to switch the lipos between a 2S configuration for powering the system and a 1S configuration for charging. Using DPDT logic level relays I can switch a pair of 1S lipos from a series configuration for discharge and a self-balancing parallel configuration for charging. Sweet.
- One button to bring them all, and in the [light of a hand held lantern] bind them. With some clever programming this isn't terribly difficult. The hardest part is powering the system up using the button when the microcontroller isn't running yet.
Chris
Jeff Cooper
Mike Szczys
