• Decoded output to utf-8.
    Kyle11/18/2015 at 07:54 0 comments
    Fixed the output so it decodes displays and logs to utf-8. It was previously printing bytecode.
  • v0.1.0
    Kyle08/30/2015 at 22:39 0 comments
    So far in v0.1.0
    - Reads CPU temp, atmosphere temp, humidity, and heat index.
    - Takes pictures through webcam.
    - Sorts unique strings during autorun.
    To do:
    - Barometric pressure sensor. Get rid of newline and byte characters on a_temp function. Add a lot more to make it the best possible space balloon/robot interface.
